When I bought my Blazer I noticed, among other things, that the water pump was leaking out of the weep hole. So I promptly replaced it, flushed the motor and radiator, and put in a new thermostat. I did check the thermostat in a pot of boiling water before installing it.
I then noticed that the freeze plugs on the sides of the block were leaking. I'm not ready to pull the motor and trans just yet, so I replaced them with the rubber type for the interim. I did notice a ton if gunk and corrosion built up in the lower portion of the water jacket when i replaced the freeze plugs. All the more reason to pull the motor, clean it and rebuild it.
Anyway, back to the point.
Before replacing the freeze plugs the engine would run cool while driving at speed. Then when idling around town it would slowly creep up hotter and hotter.
Now that the system no longer leaks is runs cool while on the highway, but after a few minutes on the street or idling the temp gauge will max out. I'v eonly taken the truck on one trip and back so i've just shut the truck off once the peg gets too hot.
What gives, this doesn't make any sense!
I guess because of the cold weather its just taking a long time to heat the coolant up, even to 160, so the air pockets aren't coming out until i'm driving around. Drove it to work this morning and the overshoot was way less than before.
