JBerno
Sorry guys, here is my long winded question?
I put a new starter on the Blazer, it had a little grinding going on once i tested it out but otherwise started like a champ numerous times.
I just crawled under it to put the shims in, that went well but when I went to start it the wheels fell off. I barely bumped the key enough for the starter to engage and lost all power to everything, I crawled underneath and the starter was lined up with the flywheel, I loosened the bolts on the starter to disengage it and tried starting it again, nothing, jumped it with my truck and still nothing.
I crawled under it again and took the shims out and it started right up (still hooked up to my truck as the battery is now dead), can I assume that I do not have a good ground to the starter? Would the shims make me loose my ground?
In the post by ekajkrats his solenoid only has one small wire going to it, mine has two small wires plus the large wire from the battery, is this correct?
Would any of this kill my battery?
There is an extra wire hanging down by my starter? Any ideas what this should go to? I will post a picture of it in a second.
Thanks in advance
Thanks in advance
but yeah, hei, your not gonna use that...
