Another Stupid 14 Bolt FF Question
BrianDamage
Alabama
Yeah, yeah I know......kill me.....but I think I'm being misinformed and don't know enough to know for sure.
I was telling a friend about my plans with my K5..kind of a long-term, build as I an afford type thing. My stock rear axle is about shot, and goes through U-Joints like crazy. I don't have the time, know-how or tools to rebuild it, and would really rather just put a 14-bolt ff in there instead.
My plan was to buy a rebuilt 14 bff, with new gear ratio and disk brake kit already installed. What I was going to do was buy some CHEAP 8-lug 15 inch rims, so that I can run the 33 inch tires that I have on it now. I was just going to unhook my front drive shaft until I could afford a new front axle (hopefully dana60).....all that means is I won't be able to drive around my hunting lease, I'll have to stay on the main road and either take a 4-wheeler or ride with someone else.no big deal.
Anyway, this guy was telling me that 15 inch rims wouldn't fit on all 14 bff axles? He says there are 2 differant kinds.I think he said one came off of a 3/4 ton, the other off of a 1 ton, and the brake drums are differant sizes, so the 15 inch won't fit on the 1 ton.
Is he smoking crack?
After getting the new front axle and lift kit, I plan on moving up to a 16.5 " rim and 38's.... but the 33's I have are pretty new and I want to get the most wear I can out of them first.
from my understanding... 15" rim will fit a 14bolt ff... and if you do disc that makes a bit more room...
drums are 13" i think and rotors are 11 or 12".....
why would you need to disconnect the front axle ?
if the gear ratio is the same as the 14bff you get , you can run the front axle
especially with 33's.
and yes you can run 15" rims on the 14bff.
A 15 inch rim with 4.25 backspace will fit on either 14bff (I had one with the big brakes) However rootbreaker is a bit off with the disk brakes making more room. When I did my disc brake upgrade I had to grind the calipers quite a bit to get the 15's to fit. Sure the rotors are alot smaller than the drums but the calipers stick out beyond that.
When I buy the 14 bolt, I'm going to have a differant gear ratio in it..that way I won't have to change it again when I put the 38's on it. It's just got the stock 3.42 (or is 3.43? :doah: ) gears now.
aight stand corrected... have only owned 16.5's :bow:
d44 calipers are smaller than the d60's so I was guessing that they would fit :doah:
I have disks on my 14BFF and 15X10's with 4.25" BS fit just fine. I did have to clean up some of the casting flash on one of the calipers, but otherwise it was pretty straightforward. :D
You should have no problems with 15" rims on a disked 14BFF. ;)
There are a lot variables like aluminum vs. steel too... (steel wheels being thinner for the same strength). I suspect that many of the things done in the CK5 article about running 15's on a D60 also apply to running them on a disc'd 14b... check there for how to clearance grind the calipers.
There are no 15" 8 lug aluminum wheels that i've ever seen. 15's on a 14 bolt is NBD, and as already mentioned at most you'll have to spend about 10 seconds grinding the rear calipers to suit...
Ironically I have run into fitment problems with a SF 14 bolt...the fins on the drum (which is a lot more outboard) had to be ground to fit the 15's on my buddies truck.
Rene
