DR
I have a 99 dodge Durango with a 5.9 that recently would not start. I found that when you turn the key on all of the gauges come on as they should except for the fuel gauge. It stays at the bottom and does not come up. I also cant hear the fuel pump running. Sometimes after a short period, the gauge comes up and the fuel pump then turns on and the engine will start. But, after ir runs a while the gauge drops back down, fuel pump shuts off and the engine dies.
Some have suggested the fuel pump relay, which Im going to replace. But, can a relay turn on and off when it is going bad?
Im open for any ideas!
