gotblazers
My grandpa lets me use his 220 or 225 volt (i forget which) lincoln arc welder whenever i want so heavy **** is no issue but its a monster of a machine and no good for taking on the trail or using on body work which as you guys have seen from my build threads i have some to do. So i was looking at mig welders at sears to keep things local and i found a few options that seem pretty good to me so i was hoping to get some opinions from people with knowledge and experience with welders.
1.http://www.sears.com/shc/s/p_10153_12605_00920568000P?prdNo=5
My top choice because it needs no gas so i could take it on the trail pretty easy although im worried it would be no good for the body work on my trucks (73 k5,76 k5,84 Burb) due to a minimum of 18 gauge. But the 3/16th max should work for trail fixes which from what ive heard since sadly ive had nothing break (despite my best efforts) consist of cracked leaf springs,frame cracks,studs and whatever else gets thrown at me.
2.http://www.sears.com/shc/s/p_10153_12605_00982888000P?prdNo=14
i chose this 2nd because it has a minimum of 24 gauge which is cool enough for body work and has a 3/16 max like the first but it requires gas.
3.http://www.sears.com/shc/s/p_10153_12605_00920580000P?prdNo=2
It has a 24 gauge minimum like the Hausfeld but only a 1/8 max and requires gas but its got the lincoln brand name.
) Im going to put a generator,Air compressor and a welder in the back of the burb where the 2nd row bench seating currently sits. So i would use the generator to power the welder/compressor as needed ideally. I Was hoping the body work welder i need would also work as a small portable low power welder i can take on the trail and use out of the back of the tow rig.
. Never thought id see a mig under 1000 bucks go that thick.
