BurbLover
Okay, I've got a line on a trailer with the following info:
Specs:
- About 12 years old. Hasn't been registered since 01.
- Had new rear axle just prior to being taken off road.
- 10K equipment trailer. Was used to haul Skid-Steer.
- Dual 7K axles w/ brakes.
- Width is 78".
- Lenght approx 18'
- Flatbed bumper pull w/ dual ramps.
- Comes w/ Spare.
- PO will have company mechanic go through axles/brakes to ensure working.
- PO will have mechanic ensure all light working via 7-way plug.
Needs:
- Needs 2 tires
- Doesn't have battery break-away.
- Deck might last 1-2 years. Pretty bad wood.
Knowing the above info, is it worth $500?
Also, with the 78", is this wide enough to haul my 90 K5 w/ 1-ton axles & 38's? This is what would be on it almost all the time.
COMMENTS/SUGGESTIONS? Thanks.
Specs:
- Width is 78".
- Lenght approx 18'
- Comes w/ Spare.
Needs:
- Needs 2 tires
