I'm getting ready to start the 350 for the first time in 7rs on a 78 k5. Do I need to flush the coolant? The system still has the coolant in it from 7 years ago. It never leaked.
I use some of those big 5 gallon buckets you can get at home depot to catch the old stuff. I remove the lower radiator hose from the radiator, quickly bend the hose to slow the flow, and try to catch as much as I can as it comes out of the radiator. I can then dump it for free locally.If you don't have a flush kit installed then I like to remove the upper hose from the radiator and then stick your garden hose into the radiator nipple and adjust the water flow as needed and then start the engine and let the t-stat open and allow the old coolant to flow out the upper hose and catch it in a bucket of sorts. Keep the engine running until you have nice clean water coming out then you can shut the engine off, drain the radiator then add the proper amount of coolant.
Some people aren't so enviromentally friendly and just let the coolant flow onto the ground and down the sewer or where ever else it will go.
in order to do a proper flush, you need to pull the 2 block drains on either side of the block.. right above the oil pan.. (which, on our rigs is stupid simple to do).. if you don't, you'll never get the sediment out of the block... no matter how "clear" the water is...
pulling the lower rad hose only drains maybe 65% of the fluid... everything in the block from the wp down is still sitting in there...
