So even though we're moving to Germany in 3 months and I have to send the truck back to my Dad for the next couple years, I still want to finish a couple more things before then. One of those is the anti-wrap bar.
I picked up a set of Kert's anti-wrap brackets for the 14 bolt and have a few of his fabricator bushing kits here as well as a Johnny joint and some 1/8" wall square tube to use. My issue is that things are getting a wee bit tight under the truck and I'm not sure I can have the bar be a straight shot from the axle to the frame. I was curious if anyone thinks it would be a huge issue to weld the brackets on the axle, and the johnny joint onto the crossmember I made and have the bar at an angle between the two. Here's a pic to help me describe what I mean...
Sorry for the poor quality but it's very bright out ATM
I was thinking weld the brackets as close to the cast housing as possible, and the johnny joint just to the left of the exhaust. If that won't work my only other real option is to come off the axle and weld the johnny joint right to the frame where it kicks up just in front of the forward spring hanger. I should be able to get that straight if I do it there, but I wasn't 100% on whether the c-channel could support the stress like that...
I was going to leave it alone, but the torque steer is noticeable enough that I think most people (ie my wife/dad) would not be overly keen on it...
Let me know what you guys think.
I was thinking weld the brackets as close to the cast housing as possible, and the johnny joint just to the left of the exhaust. If that won't work my only other real option is to come off the axle and weld the johnny joint right to the frame where it kicks up just in front of the forward spring hanger. I should be able to get that straight if I do it there, but I wasn't 100% on whether the c-channel could support the stress like that...I was going to leave it alone, but the torque steer is noticeable enough that I think most people (ie my wife/dad) would not be overly keen on it...
