looks good but with a pair of bars isn't it going to bind when the axle is flexed?
I think your missing the slip tube design? With joints to allow rotation and the slip tubes to allow the lengths to change it should do well.
. i did alot of research and planning before i started building. i made sure to do it right the first time
Looks good.
I believe this truck is used for pullling. Is that correct?
I love that set up i wish i could fab up stuff like that! can i ask you if their are any prefabed kits besides the wraptor from kert that you or anyone else might recommend? nothin against his gear its beautiful i just dont have a 14b. also what are you using for the paint? where everything is connected to the truck its that rich black finish, how are you doing that?
truck pulls or just towing?
might not hurt to truss it with like a BTF truss, something that welded to the axle tubes and wraps over and bolts to the pinion housing to also help keep the tubes aligned
