84CUCV 3/4 ton status Joined Jul 1, 2002 Posts 7,150 Reaction score 2 Location NJ for now Jun 26, 2011 #1 this is my 6 am morning project... got the new fuel pump. any things else to be done why im there that makes sense to do? thanks
bronc3buster842001 1/2 ton status Joined Sep 30, 2006 Posts 2,000 Reaction score 7 Location leadwood missouri Jun 26, 2011 #2 Pull the bed off. Alot easier than trying to fight the tank. When I did mine, I unbolt the bed and use a cherry picker to pick up that side.
63chevyll 1/2 ton status Joined Aug 13, 2009 Posts 4,576 Reaction score 71 Location Colorado Springs Jun 27, 2011 #3 Don't use a carter pump and I prefer the tank method. Good idea to do fuel filter too.
84CUCV 3/4 ton status Joined Jul 1, 2002 Posts 7,150 Reaction score 2 Location NJ for now Jun 27, 2011 #4 ok why? i have a carter pump. tank method? you mean drop it down?
63chevyll 1/2 ton status Joined Aug 13, 2009 Posts 4,576 Reaction score 71 Location Colorado Springs Jun 29, 2011 #5 Just save the receipt, they have a history of failure, and yes, just pull the tank, or what ever is easier for you, but the tanks come out easy
84CUCV 3/4 ton status Joined Jul 1, 2002 Posts 7,150 Reaction score 2 Location NJ for now Jun 29, 2011 #6 ok thanks ill go get the bosh or ac delco one
63chevyll 1/2 ton status Joined Aug 13, 2009 Posts 4,576 Reaction score 71 Location Colorado Springs Jun 29, 2011 #7 ive had better luck with the Delphi pumps, which is a factory replacement, becides delco
84CUCV 3/4 ton status Joined Jul 1, 2002 Posts 7,150 Reaction score 2 Location NJ for now Jun 29, 2011 #8 ok thanks
