trevmountain
Just curious if anybody has installed the ORD 1 inch body lift on an mid eighties K30, mine happens to be an 84. I started the task today and it's looking to be quite the ordeal.
First question: What's the deal with the body mounts for the cab? Do I have to pull the carpet up? The bolts go up into the floor pan so there is obviously no way to access a nut. Is there a threaded capture nut or something. If it is a capture nut can I just hit em with the impact gun?
Second question: Can I hit the bed mounts with the impact without spinning the dome styled bolts, (sorry forget what they are called). If that's not the best option how does a guy go about popping these loose? How do you hold them? If I recall these dome styled bolts have a square base that should seat in so in theory I should be able to hit them with the impact??
Also if anybody has any tips of jacking locations and or ideas of materials used to hold the body up the most effective way. Also what kind of poundage should I retorque the bolts to when re installing.
Thanks in advance
Thanks in advance
