doonjumper
Can I use mig or do I need to use Ni rod when welding on them?
That's what I meant cast iron.Yes cast steel is different then cast iron.
To properly weld cast iron you're going to want to preheat your work to 500* nice and even and get the surrounding material warm so it doesnt wick the heat out too quickly.
You'll want to use Ni-Rod as you mentioned. Weld it just like steel as far as amperage and feed goes.
If you're welding a lot of stuff you'll want to stop and reheat the areas as you go. Once done welding post heat the work back up to 500*. Next you can either wrap the work in a welding blanket to slow cooling or submerge it in sand. If you're doing something like I did where I welded brackets to my pumpkin side spring perch up front and its not really feasible to wrap or cover in sand with your resources you can post heat with the torch in steps until it cools. I took about an hour to do this, baby sitting it as it cooled. Allow it to cool for about 10 mins, reheat the surface gently and bring it down in temp in about 75* steps.
