Any door alignment photos?
chevy111
Sutter, California
Can someone post on here some pics of their doors aligned. I am aligning mine and can't seem to figure how high or low the doors go. I replaced the rocker boxes and now the doors seem a little high. As far as I can tell I put them exactly as they were before, but I also have new doors so I may have to do some trimming. Any photos would help greatly epecially close ups of each corner. Especially nice big ones so you can see well.
Hey Icebone here is a couple of pixs of my drivers door. Its only of the upper top section. If you need I can take a pix of the whole door. Good luck.
Those are exactly what I was looking for. My doors look more like your second picture. Did your doors drop alittle later? The top body line on the door is a little higher then the top of the bed in the second pic but lines up real close on the first pic. I bought a single wall top and the door didn't seem to line up with the seal on the corner. Seems like the door is high but the body lines line up. Does the top have some adjustment? I have had a ton of issues with alignment. It took me 3 days to get the front end to align.
Your right about the alignment problems with single wall tops. The doors in these pixs are from a truck. I cut the tops off. Trying to align them is an on going problem. Recently I went ahead and add extra spacers on the back drivers side body mounts to help with the alignment issue. My blazer is in the body shop this week. When I pick her up next week Ill snap some updated photos of the doors.
I have no issues on the gaps just the height of the door. It lines fine with the body lies so hopefully I can just trim the rubber to make them fit.
