Any interest in a sandblasting/POR-15 frame restoration article?
Desert Rat
Fetch the comfy chair
Tri-Valley, NorCal
I'm in the process of redoing my frame. I bought a Sears sandblaster and just finished cleaning the frame. Next step is the POR-15 frame kit including POR-15 undercoat and chassis paint. I'm shooting pics through the process. Anyone have any interest in an article on the project?
sounds good...I may do that as soon as the temp rises here a bit
heck! i'd like to see it.where's tri-valley?have fun /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
Dublin, Pleasanton, Livermore. More than a few Tri-Valleys about I imagine. I will shoot some pics of the blasted frame today and will be starting the POR-15 base coat as well. I'll try to write it up soon.
I'd like to see that.....
I've got a sandblasted frame sitting in my garage, and I'm in the process of blasting the inside of the cab...not sure if I want to use a POR-15 or an acid-etching primer to seal the fresh metal though....
i plan on starting next month so i could use the foresight.
nathan
I'd suggest the primer...
POR stands for "Paint Over Rust":
it doesn't adhere well to fresh metal.
Gavmaster
Well, I just laid the first coat down of the POR-15. I will do the second coat here in about an hour. I have to say I am very impressed. Just with one coat it already looks great. Almost a powdercoat type plastic look finish. I disagree that it doesn't adhere to bare metal well. In fact, the brochure says it will do very well with sandblasted bare metal which is what I have. After the second coat dries, I will then be painting it over with POR-15's Chassis Black. They aren't kidding when they say that once on your skin, only time will remove it. So far the project is going well and I am taking pictures along the way. I will have to save out the areas that need welding for later. I thought about waiting until all the welding was done first before painting but I didn't want the bare metal to start rusting again before I got around to painting.
Oh, and I am doing it with the body completely off and everything stripped off of the frame. I will try and insert some pics as soon as I get myself a web site, which I've never bothered to do.
Sounds like a great idea for a write-up. I am definately very interested in it! I'd like to see how it comes out and how much you use to cover the whole frame.
Kris
Did the Chassis Black coating today. I plan on doing the write up as soon as possible but if anyone just can't wait, pm me or send me an e-mail and I will send you the pics and some suggestions.
