Brainstorming stuff for my 1959 Chevy Apache project. The truck has a 2005 5.3l LS in it.
I am disguising the engine to look more retro. I already have valve cover adapters and some SBC valve covers on it. I plan on swapping the factory intake for a Holley or Edelbrock intake that will allow me to run a standard round air cleaner. The ignition coils are going to be remote mounted.
Now here's my idea. I think I will have enough room to mount a distributor cap on a round plate at the back of the motor. i was going to drill out each spark plug connection point so that I could run a plug wire through it. Then route them through the fire wall and have the ignition coils mounted inside the truck under the dash board.
This would really get people to scratch their head when they look under the hood
I think I will probably have to order 2 spark plug wire kits as this will definitely add some length to the wires. Do you guys think I will see any issues with longer spark plug wires? The engine is totally stock right now. Just has CPP exhaust manifolds. In the future it will probably get a cam swap, but nothing crazy. It is going to be a street driver, no racing
