Any one with a 88 Suburban, Blazer or truck
Metrodps
Strange but nice guy
Author
earth
I need a clear picture of the label on the door for a V10 1988 Suburban. OK got that done. Need to know build dates and first three vin seq. example 1GNEV16K1JF167xxx then the date of build will work on R and V trucks, Blazers and Suburbans.
They sanded the one off on the DP burb:mad1: found the companies that make repos not sure if they will do it with out the original.
To be honest, I'd start with the glove box RPO codes. It can vary between vehicle depending on the options on your particular truck.
Not to mention it really doesn't need to be there.
mines not in perfect shape but its an 88 and can mostly be read... hope this helps a little:dunno:
You may not care but I am anal about things being right. Beside it was there and in perfect shape prior to... Beside this might be in a magazine and I want it to look as perfect as I can.
I need the two middle number area info on it. Thanks shady :thumb:
Shady thanks that will help to have a new one made it will be $125 ouch!
OK Shady's was made before mine. His was 129xxx and mine is 167xxx.
