k20
3/4 ton status
Hey guys, been working on my dads 96 7.3 powerstroke. Its only got 90k miles on it (it sits way too much). I have posted on a couple p-stroke forums and havent gotten a whole lotta help, so figured Id see if anyone here had any ideas. This is gonna be a longggg post, but figured Id get all the info out there.
Last week I drained both fuel tanks (fuel was nasty), treated them, replaced fuel filter and it ran without a hitch for me for several hours. Left it with him, and when he went to drive it yesterday, no dice, wouldnt fire. Just spun over. He tried it 4 or 5 times and then drove his other truck to work. Now it was between 35 and 40 degrees yesterday morning.
While I was checking the GP's I noticed a fair amount of fuel in the lifter valley. I thought I cleaned it all out last weekend after doing the fuel filter, but maybe not. Anyway, washed it all out and so started the truck to dry it out. Let it idle approx 15 mins while I picked up tools, etc.
Got in it, backed out of the driveway, turned the corner and got on it hard. Made it to third gear and it was like the throttle just quit working. It quit pulling wouldnt rev, nothing, pushed the clutch in and it cut itself off.
Hit the key and it turned over for approx 5secs before it caught and after that it ran just fine.
Drained the filter housing again just to see if any water had collected since the tank draining. So I had it idling and was rinsing out the lifter valley again and when I got up behind the HPOP, and was spraying down the truck kinda stumbled. I quit spraying and started looking.
From the passenger side, I reached down towards the HPOP (on the pass side there is a large hex headed plug), and when I pushed the high voltage (red wrapped) harness out of the way, the truck shut down just like somebody turned the key off. Went around and it fired right back up and shut right back down. Hit the key again, blipped the throttle and it idled just fine. Went back around and wiggled every wiring harness in site and it wouldnt do it again.
I was degreasing the engine to make it a little easier to work on. When I was rinsing it off, I decided to fire it up and see if I couldnt find out what the wire wiggling/cutting off was about with the shutdown. So its idling along and the second the water hits the CPS, it shuts down like you turned the key off. It will refire as soon as you turn the key, but if you hit the CPS with water its dead.
Sooooo, yesterday I changed the CPS & the glowplugs out. While I was at it also changed the oil (it was about time anyway). Now it will actually start when its sub 50*, power seems up slightly. However, again, I had it sitting idling, warming up while I was picking up tools and it shut off
. So I hit the drain valve, get just a little water/nastiness out. So I take off the 2 bolts that hold the regulator on the side of the fuel bowl and there is alot of sludge (algae looking crap) stuck to that screen.
Cleaned it off, put it back together and then it just wouldnt fire. Turned over and over and over, let the starter cool off and did it again. Had to repeat that 3 times, then it fired up and ran fine. Also didnt notice any smoke while it was turning over, but its hard to tell its windy out and its got the dually fenders blocking a straight view in the mirror. It should not take that long to reprime, I didnt let but maybe a few ounces out when I drained the bowl and hardly anything came out when I took off that regulator.
This morning it was 30* (what happened to fall)? Anyway before I tried anything, popped the hood, checked the HPOP resevoir, its full. Hit the key WTS light came on, when it went off, turned the key it fired right up.
It ran at a slightly elevated idle (approx 900) for about 45secs. Then the tone of the engine changed a little (almost hollow sounding), check engine light popped on and engine died immediately (those 3 things happened in a span of about 5 seconds). Turned key, restarted. Same deal, except it ran slightly longer, about a minute. Third time it only ran for about 30 seconds then died with no check engine. Once more and it ran for about the same amount of time except it didnt go into the elevated idle, it just ran at its normal 600rpm.
Checked HPOP again, its still full, so atleast to what I have read the ICP isnt telling the IPR to dump all the oil due to high pressure, and the IPR isnt sticking and dumping all the oil, or could those still be culprits?
Well thats a lot of cutting & pasting to get the whole story off one of the p-stroke forums, so if something doesnt quite make sense, its probably b/c of the cutting and pasting. Anybody have any ideas for what I should check next?
