Any reason not to...
38377k5 said:
If POR15 leaves a smooth surface, put it on the wheel mounting surface but not the axle mounting surface.
Do you mean don't paint the surface against the rotor? Is that a concern?
Do not paint the side that contacts rotor, other side is fine to paint
I would paint everything that will see exposure to the elements.
I wouldn't paint the mating surface between the hub and axle itself (that is a FF axle hub, right?)
Basically, you're not going to hurt anything by painting it. You could have issues with sealing against painted surfaces. Paint can run and be uneven, the bare machined surfaces should be damn near perfect.
