So my brother has been combing the area for an RV and we finally found one for a cheap price. Needed some work but overall condition is good. Generator didn't work which led to other things not being able to be tested. This helped with the price negotiations
With some new parts and some work, I've gotten the generator to work, redid some sway bar bushings, replaced the shocks, and a few other things. I'm getting a slight vibration while driving up front and those items looked to be contributors to this issue (and they were worn out). But I'm still getting some vibration.
I jacked it up and could get a little play in the front wheel at the 6-12 o'clock positions. The ball joints didn't move so it looks to be the front wheel bearings.
I've found the bearings and am set to install new ones (may even do the brakes and rotors while I'm there), but can't find any torqueing specs. I'm assuming it's going to be close to the K5 front hubs, but haven't found anything specific.
Anyone know the torqueing numbers for the hub? Any special hub tools? Size? One of the shopping carts from Autozone shows a 2-1/6" socket.
Thanks for any tips.
.With some new parts and some work, I've gotten the generator to work, redid some sway bar bushings, replaced the shocks, and a few other things. I'm getting a slight vibration while driving up front and those items looked to be contributors to this issue (and they were worn out). But I'm still getting some vibration.
