Any suggestions?
South Carolina
I have an 89 k5 blazer, and 2 days ago the transmission started to hesitate/slip when goin into 3rd and 4th. The tranny was rebuilt professionally less than 5000 miles ago. The fluid level is good, and there is no dirt, grime, grit, nor is the fluid burnt. Any suggestions? Thanks guys.
Check your TV cable. If that doesn't reveal anything, take it back to the place that rebuilt it, assuming they warranteed their work; which they should if they are a professional outfit.
What they said.
It's likely either the t/v cable is a hair too tight or a bad clutch pack.
Take it back to the tranny shop ASAP.
