handloader90
Building!
Mating a LS 6.0 to a SM465 and have the flywheel, clutch kit, pilot bearing and the associated metric bolts ordered and heading my way.
I noticed that Novak sells an adjustable ball pivot for SM465's. I believe it is mainly to go with their hydro clutch kits and when doing conversions such as a SM465 to say an AMC engine.
Any use for this thing in a stock SM465 using mechanical linkage setup?
I ****ed my clutch fork up when pulling the old SBC... don't know how but that spring steel clip inside of the fork was broken and fell out of the clutch fork.
Figured I would replace the ball pivot at the same time, thought that it may have worn out over time with specific wear to the old clutch fork.
Below are screenshots of Dorman P/N's of what I plan on getting.
Dorman lists the parts as compatible with eachother in addition to being the proper parts for a '79 K10, I have a '79 K5 which I'm going to assume has the exact same setup.
