anybody hava a sas'd 88-99?
1BEATK5
beaverton orygun
im looking for some opinions on the quality and design of the kit you bought.
what brand was it?
did it fit well?
are they thick (heavy duty)?
what do you have for steering?
how is the front d-shaft angle?
what changes would you make if you did it again?
so far i looked at
ORU
SKY
Off ROAD DIRECT
i think i am going to use a 36.5" ford axle, so the new ORD kit wont work. maybe by the time i'm ready it will be. or maybe DIY4X4 will hae his out too.
Is kert doing a SAS kit now too?
Im really surprised these havent caught on much much sooner, seeing as us chevy guys are REALLY limited on fuel injected, solid axle, trucks to start from.
Seems to have been alot more of this within the last couple years than ever before.
you behind the times. thay got them all out for test. and 32" version only at this time. later for the wide 36.5" thay said.
most likely 11.0x16" michelins or maybe some 37" bfg's. no bigger.
im thinking about pushing the front forward a bit for more clearance and less:hack:
You may want to look into fairly little backspacing on your wheels, our shop Superduty rubs the springs at full lock on 33's!
We will have a kit soon and if you're willing to wait a couple weeks, send me a PM and maybe you can be the first to test our 36" spring pad width kit!
i have heard about the rubbing issue. i want to look into that before i commit to an axle. i dont want to be frogged out to stay off the springs.
