R72K5 said:
but most ppl who have car traielrs dont use the brakes, no one around here does anyways, cept some rich ppl with new trucks and such, but still uncommon
the dually brakes are huge, and 71-up are huge disc front and huge drum rear of course, hella safer than pulling a 16 or 18 foot loaded car trailer with a 1/2 or 3/4 ton SRW like everyone here does,.....
Actually, no. Pulling a "car trailer" in Illinois without brakes is illegal in Illinois. Not only that--pulling a trailer over a certain weight without a brakeaway switch is ALSO illegal and you're also required to have brakes on every wheel that touches the road.
That said, I don't put my truck on a, "Car trailer." I use a 14k GVWR equipment trailer. It was only $3,000 man, it's not worth losing your life over having insufficient brakes.
k5redneck said:
i have a cab chassis truck for towing. im just looking for someone to split the cost with me to get a two car trailer. now thats killing two birds with one stone....
There isn't a pickup on the planet that can safely tow two fullsize rigs. The trailer that long would likely weigh 7000-8000 lbs (Gooseneck tandem dual). Two fullsize rigs even on a diet would be 5000 lbs each. That's 17000-18000. Dunno what kind of tow rig you have but my new Cummins has a GCWR of 21,500 and with 4.10s it'd be 23,500. Truck weighs 7012 with nothing in it, so supposing it had 4.10s, 23500 - 7012 = 16488, still shy of your conservatively estimated weight of 17000-18000 for a trailer with two fullsize rigs, which is probably more like 20,000 by the time you get them all loaded on a heavy duty trailer.
As stated above, you will bust the GVWR of a 1 ton rig when hauling 5000-6000 lbs on the back of it. 10,000 lbs is a common GVWR for older DRW rigs, subtract minimum 7,000 for a rig that big/long and you've only got 3,000 lbs for payload, putting you 20% or more overloaded by hauling that truggy on there.
Just get a trailer man, you're trying to over-do yourself. Just because you see guys carrying stock cars on the flat beds of trucks doesn't mean it's safe.
