My blazer is my DD and it has a 350 with an edelbrock 1406 on it, electric choke has never worked and it has always taken about 10-12 seconds of cranking to get it started in the morning, hot or cold weather and even when I manually close the choke by hand it doesn't make a difference. It seems that when I go to do a cold start on it every morning the best routine to get it going is to not pump the gas first and just crank it for like 8 seconds to get the fuel pump pumping gas to the carb, then give it a couple pumps and it fires up... Is there any way to stop this fuel drain back into the tank overnight? Cause I'm also burning through a starter about every 3 months lol. Any ideas? I was thinking of converting to manual choke but will choke even help this issue?
