Anybody have MArker Lights Installed on their Roofs?
how hard is it to wire them though? i have been waiting to put some on mine as well..
They ground through the mounting screw. After that, it's simply a matter of hooking them to your headlight switch. There's also a wire down by your radio that comes on with the parking lights...you could use that if you want.
Mine are wired to the left front parking light. I also hooked my tach up to it. The reason I did it is because back when I was 16, I didn't know how to tap into the parking light switch so I just tapped right into the parking light. Either way, you just need +12v to come on with the parking lights. It's easy to wire.
Hide them inside the door seal. I drilled holes all the way through for the wires. If you don't want the wires above your sun visors, use the holes that mount the sun visors and fish the wires through. I didn't care if the wires were up there above my sun visors, so I just drilled all the way through.
From where to get the measurments
mayebe some K30 guy can throw somekind of drawing ?
I used a ruler, found the center, decided on a distance back from the windshield on mine. I drew that location on my roof with a pencil, then placed the others the same distance back away from the windshield and did all the measuring from the center. It's hard to explain, but it worked out great for me. Just make all the measurements relative to the other lights so it looks uniform and they'll turn out alright.
How far it this centerlight from windshield and how far
are those oher lights from center ? /forums/images/graemlins/1zhelp.gif
( sorry for asking those stupid guestions )
If I were going to install any cab lights, I would use the newer Chevy style lights.
