Will do when I get homeCan you show a picture from further back?
Thanks, don't know why they make it for the first gens but not the squares. The junkyards around here have only late model stuff. I have no problem making the part- might take a few tries,haha. Appreciate the positive comments on the welds. I've come a long way. Before I started this, I could barely stick weld broken farm equipment
Yeah I'll make a template once I get the rear quarter out of the wayOkay yeah you have to make that part. I wasn't sure exactly which part of your trying to replace but it makes sense now.
I tried making my own lower B pillar with mixed results. The metal on the late 90s lower B pillar is thicker then the body panel so it is not easy to form. If you do not get the curve correct it will not align to the rocker and rear quarter. One would need a jig and a press to make the part correctly IMHO.Yeah I'll make a template once I get the rear quarter out of the way
Whoa, yeah. I thought mine was jacked up. That helps, thanks! Looks like you had to reconstruct most of the b pillar as well as the rocker assembly. I didn't know that part was in the 76- bodies. Thanks for posting thatHad to rebuild that part myself on my project. 1976K5. Notice the shinny bottom on the support. I also had to rebuild the thicker plate that the piece is welded to and the seat belt is bolted to.
1View attachment 441686
Not 100% finished yet, bill complete when I weld in new floor sections.
