That is a ground wire. It connects to the back of the engine block. It needs/should be hooked up.
Check for one at the core support by the battery as well. Cab and core support is rubber mounted with no direct frame contact for grounding.
When you say "core support" are you saying the radiator?
sorta.. the radiator attaches at the core support.
If that is unhooked you will have electrical gremlims!
More than likely, at least thats a good start.I hope this is the answer to my dash gauges / headlight switch problem.
nice!!you need to have the grounds hooked up, on my nova i left most of them off and somehow the shifter cable became the main ground between the engine and body and it burned up, almost burning up the car along with it.
