Hey guys, my 1998 XL1200S is running rich and I can't figure out why...
Super Short Backstory
I let it sit for a few years. When I started it again for the first time it revved to the moon. It would only stay running with choke pulled. I replaced the intake seal where the carb sits. After that I cleaned the carb and the tank which led to a rabbit hole of doing all sorts of things. Now it's running really rich and I'm running out of ideas on how to fix it.
HERE is a link to a short video that shows the bike running and lists everything that I've done so far.
Listed explicitly:
Listed explicitly:
- Rinsed out tank (2x)
- Cleaned carb up and down (2x)
- Verified float level
- Verified jet sizes (45 / 185)
- Tested and replaced petcock
- Checked the slide diaphragm
- Adjusted the mixture screw (1.5 turns from seated)
