Anyone ever put a diesel torque convertor in (TH400)
k30gambi
illinois
That's what I'm doing, its supposed to be 1300rpm stall speed and a gas one is 1600 (speaking oem). 90 bones for the tq, figured I'd try this rather then spend 250 for the TCI high torue (low stall) tq. /forums/images/graemlins/grin.gif
i did but it's behind my 6.2 /forums/images/graemlins/grin.gifi dont know if there all the same or not but mine has 6 Torque converter bolts so good luck /forums/images/graemlins/thumb.gif
later,
Jerry
The diesel ones dont like going over 3500 rpm. after that they can balloon and explode, its a hella mess when a torque convertor comes up through the floorboards.
Youre saying that a diesel converter is not balanced as well as a gas one, or the parts are heavier or what, or are you just assuming that since a 6.2 never goes over 3500 rpm, the torque converter cant either.
??? This is news to me. I'm running one now in the TH400 that was behind the 6.2 that came in my truck. I just bolted a 350 in front of it... AFAIK, they are nothing more than a standard TC with a lower rpm stall. The "stall value" depends on who you talk to. I've heard anything from 600(?!) to 1200, but the point is, it won't slip to as high rpm as a stock gas converter will. This can help keep heat down, and it can make finese in the rocks easier if you use it right, but it will make the gas motor feel weak since it can't get near it's power peak before having to start twisting the drivetrain, and when you *need* that wheel spin to make it, you may not be able to get it (especially when you need to spin 42s)...
Jeeez, that would be pretty crappy. A friend of mine put a deezul convertor behind his 460, thats why i was going to do it. 427, I never heard of them "balooning" thats a pretty balzy statement, are you sure (proof)?!?!
Balooning is a real problem. But it doesn't generally surface until 6k+ on drag race trannys... Usually its more like 8k before you get really shaky, but anything over 6k is a good bet for a high rpm converter. That's also why they make special bell housing to contain a blown converter. You don't want that crapt coming at ya unless you want legs like mine, trust me, you don't... /forums/images/graemlins/frown.gif
