4by4bygod
Question prolly belongs on a dodge forum, but I trust you guys so here goes..
one of our spare trucks is the wife's 98 durango with the 318.
I took the passenger front wheel off to investigate a rattle, and found that one of the caliper bolts ( lower ) had backed out, causing the caliper to shift a bit and make some racket down there.
the last shop to do the brakes used an air tool to put the wheel nuts on (assholes), so i am guessing they put the caliper bolts in with one too.
anyway, I can get the bolt to start and go it, but it won't snug. the bolt threads are a bit boogered, so I got new bolts, with the same result..it'll start and go in, but won't get tight.
anyone know offhand what size tap I need to buy to fix the threads in the bolt hole? are the sizes different between the dodge and GM?
Thanks!
Thanks!
