Okay, guess I should have put more info in the first post. 1989 Honda nx125, 4 stroke. I did try to clean the carb out, but didn't mess with and settings because I couldn't find the factory ones, since this isn't the most common bike. I did try to adjust the idle control, but I would have to lower it so much that the bike would start to die, then when I brought it back up slowly, it would go back to where it was. It has electric start, not kick, but it starts easily with the choke.
IIRC, the float wasn't sticking when I cleaned it. I'm also having another possibly unrelated problem. If I open the throttle too quickly, it bogs down, but only in a low gear. At first I thought I has an accelerator pump problem, but it looked fine to me. It also skips around a little at high rpm sometime, not sure if that is an ignition miss or something clogged in the carb.
As I'm writing this, I'm realizing it probably something that is still clogged in the carb. I'm leaving tomorrow, but when I get back I'll clean it out again and if I still have this problem, I'll ressurect the thread and ask more questions.
Thanks for the help
