Willing to do a huge favor and measure the bolt pattern for the brake backing plate?
If you happen to have the wheel off, from the outside face of the backing plate to the back face of the axle flange?
Trying to figure out exactly what is up with the later disk brake setups, and if they are "backwards compatible" with some of the earlier housings.
So far I've seem it referenced that the brake backing plate pattern never changed, but even if it didn't, the axle flange to backing plate spacing would require some adapting.
Thanks!
Thanks!
