Anyone have a Mounted First Aid Kit/Auto Emergency Kit??
garydan
Port Saint Lucie, Fl.
After I get the interior Line-x'd this week or next, I'd like to mount a first aid kit and a fire-extinguisher in the cabin. I'm thinking of mounting the first aid kit in the back along the side.
Anyone know of a good product for this? Links Please :D
how about an ammo can painted white w/the red cross painted on its side.
edit: you could weld a small flat tab on both sides of the ammo can flush w/the bottom & use a piece of angle iron w/a slot to slid the tab on the ammo can in & the other side use a battery hold down that pinches the bottom of a battery to secure the ammo can wherever you want to put it, and if you use a butterfly nut the 1st aid kit can be removed quickly and carried to where its needed, instead of having to go back and forth to the 1st aid kit, plus ammo cans are water tight if they have a good seal in the lid..
I have my interior line Xd ive got fire exhinguisher mounted infront of my center console attached to console itself.
Ive got a soft cased first aid kit. Ive got a 4 point roll bar and will probably mount it to that or ill get one of those molle seat covers with attachment points on the back of it and you can add pouches and what not, so I may go that route sometime.
I keep a FA bag in the center console, Its always seemed that the guy carrying the FA kit isnt the one who needs it so I keep it easily accessable. Also i like this bag because everything has its place and everything is separated making for "easy access" :rolleyes:
