anyone have an install manual 4 banks?
jp0863
clovis, ca
gonna start my install soon, does anyone have an install manual or a link to where i can find it? called banks, e-mail banks, and still they dont understand what i'm asking for. even told them "i need the installation manual" and they still sent me just a brochure... and i offered to pay for it as well... still nothing.. so if anyone here can help, i would appriciate it.
I spent a long time looking for that manual as well. There site isnt the easiest to find stuff on. Make sure you have all the small parts, if your kit is used than make up a list of everything you need and make one order. be sure you get the CDR hose, the lower radiator hose, gaskets, and you might need to get new lock nuts that hold the turbo to the manifold (Banks only and they are $8 ea.) Stainless Steel Collet Locknuts and of course there fine thread. I am almost done with my install, hoping to finish later today.
Is your kit the early model that drains the oil into the oil pan, or the later model that has the spacer block for the lift pump?
mine is the later kit that drains into the lift pump. luckily the turbo is still attached to the manifold.... 86dieselburb, thanks for the info. i have checked their site before, but i guess not good enough.
Trust me, took me awhile to find it. Hope it helps.
i found it, thanks. printed it out at work (why not use their paper and ink). been a little busy to check back here as often as i like, sucks being busy.
