after looking at things with my truck im more and more looking at propane for a few reasons
1.simplisity-im currently running a 400 sbc carbed with a rv cam (dont know the specs)its gonna be alot easier getting it to run on pane then a tbi setup
2.later down the road i wanna bump the compression up and do some changes to the motor for more power
3.cost-if i bump my compression up then the pane will run more effiently and the cost of payne vs. 93 or a racing fuel mix will be much cheaper
the down side
1.accesibiltiy to pane is not as easy as gas
2.if you run out you have to have a second tank at all times
3.it burns faster than gas unless your motor is built around it
4.no gas guage (the tanks arent very accurate)
5.the tanks take up more space (cant hide undernieth the truck)
now mind you i put somewere around 25 to mabye 50 miles a week on this truck (cruise ins,saterday drives) but i hope to make more wheeling trips (hopefully 1 a month)
can anyone gimme a reason why i shouldnt go ahead and start dong this??i dont want the carb any more (i just dont like them) and i think tbi is gonna be to sensitive for what my plans now and later are gonna be...
the down side
You know there are dual fuel conversions available for gas/propane, right? That's the way I kinda figured I'd go. That way you can still run on gas, but have the propane for trails. Or you can run propane all the time, but have gas for emergencies or long range trips.
) but i just dont want to go tbi now and then later have major headaches or be limited to what i can do to my motor
