handloader90
Building!
I've been doing a little research and came across some threads on nylon brake lines over on pirate4x4. Speedway sells a kit w/ 25' of line and compression fittings. I believe the hose and fittings are rated at 1900 PSI and the kit costs around $30.00.
I'm really considering running this on both front and rear axles. Just wanted to know if some fellow CK5er's are using it and if so how do you like it?
