Anyone know about aftermarket pullys?
Burt4x4
1 Ton First Gen
California (Modesto area)
I'm having troubles finding my waterpump pully for the 454/forums/images/graemlins/1zhelp.gif
It's lost in my garage or the dog ate it /forums/images/graemlins/dunno.gif or I thought it was a 350 pully and gave it away /forums/images/graemlins/doah.gif
So if I cannot find the pully I am now thinking of aftermarket stuff...or junkyard time.
How do you figure out what works?
Is is just the water pump being long or short?
I belive I have a long style pump?
you mgiht want to check some hot rod supply place's i bet they would have one, mabye year one, might be kinda expinsive /forums/images/graemlins/dunno.gif
i saw a 454 a few days at the local yard with all the pulleys I'll check it out and see if it's there. I think the 350 stuff should work. the pumps seem the same /forums/images/graemlins/dunno.gif
ARQ.
ARQ.
all 454's are lwp.no the 350 one will not work. let me dig around burt i think i have a couple layin around. i bought chrome ones,which i do not reccomend ican't get my belts to stop slipping with the chrome! i am ready to go back to painted! /forums/images/graemlins/eek.gif
Burt, I'll look in my parts pile and see if I have one. If I do and it's good you can have it for the shipping charge.
Thanks fellas, you guys are AWSOME!
I'll keep you posted on what I decide to do...
One thought is to go this route:
Or something similar, hmmmmmm
wowow those are wayy cool,
hey rubbinz mabye try hittin the inside of the pully's with a wire wheel? might scuff it up a little so they dont slip /forums/images/graemlins/dunno.gif
Burt, I do have one it's a 2 row with the inner being a smaller diameter than the outer. Let me know if this will work for you. A quick guesstimate on shipping would be between $5-$8.
Cool Man! I will let you know if I need it...still thinkin/researching my options /forums/images/graemlins/confused.gif /forums/images/graemlins/waytogo.gif
[ QUOTE ]
all 454's are lwp.
[/ QUOTE ]
Really now?
BBC Short Water pump-->
http://store.summitracing.com/partdetail.asp?part=EDL%2D8860&N=110&view=4095&applid=%7BC84C0DF0%2D9094%2D48ED%2DA051%2D19EF4C71EFA8%7D
BBC Long water pump-->
http://store.summitracing.com/partdetail.asp?part=EDL%2D8864&N=110&view=4095&applid=%7BC84C0DF0%2D9094%2D48ED%2DA051%2D19EF4C71EFA8%7D
Short Water pump pulley-->
http://store.summitracing.com/partdetail.asp?part=SUM%2D329815&N=110&view=4095
Long water pump pulley->
http://store.summitracing.com/partdetail.asp?part=SUM%2D329723&N=110&view=4095
I believe with the stock pulleys and brackets, if your alternator is on the passanger side then you have a short water pump, if the alternator is on the drivers side of the engine you have a long water pump application. ..at least that was my understanding of it while i was researching BBC pulleys when i needed to order some for my BBC.
...Those cog belt pulleys are sweeeet. Love em on my BBC. /forums/images/graemlins/peace.gif
Dammit burt, now you got me thinking about yanking my Rat outta my camaro and dropping it in my K5 for our grudge match. /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
Thanks RB...no no leave the BBC in your car. If you want to you can just ride with me after I SMOKE YOUR DOORS OFF /forums/images/graemlins/yikes.gif
hahahah JK
Your SBC TPI will be fun to race up CompHill /forums/images/graemlins/waytogo.gif
I'm thinkng 1"cogbelt setup would be killer! But my budjet is allready WAY OVER /forums/images/graemlins/ignore.gif
I hope you find one local, if not let me know. I got a few.
the best way to contact me is by phone.
480-710-6967
-shawn
sorry ryan i guess what i meant to say was factory 454's are lwp. except maybe some of the early 70's corvettes. i think gm went to the long style in 69? but i know you can still get the short style! /forums/images/graemlins/doah.gif
That would make sense..
On that water pump application chart it said SWP 65-69, LWP 69-75.. but then when was the first year for the 454?
What i was getting at is reguardless of the year block he has, he could have picked up the long or short water pump, so it would suck if he bought LWP pulleys only to find out he has a SWP. /forums/images/graemlins/doah.gif
When i bought my camaro it had a 73 block but a SWP setup. /forums/images/graemlins/dunno.gif
[ QUOTE ]
[/ QUOTE ]
hmmm, I have a LS5 block I picked up witha long water pump on it /forums/images/graemlins/confused.gif
seems I have some reading/ learing to do here /forums/images/graemlins/thinking.gif
Dan found my original one /forums/images/graemlins/confused.gif I must have gave it to him with some of the SBC stuff I gave him a while back /forums/images/graemlins/rotfl.gif
Now I just need to find the lower altanator bracket /forums/images/graemlins/confused.gif /forums/images/graemlins/whistling.gif
