Anyone make a 1" motor mount lift?
jp0863
clovis, ca
Does anyone make a 1" motor mount lift to go along with the 1" body lift?
I've seen MML's and t-case lifts for Jeeps but never for a full size Chevy.
if you replace the motor mounts with the ones at DIY4X.com it will probably pick it back up an inch off those worn out mounts.
Why do you need to lift your motor up an inch? Clear the fan shroud? I just trimmed mine, If you still need to lift it an inch I bet kert could make you some of his solid motor mount an inch taller. DIY4X.COM
I'd think the easiest thing to do would be to have someone make you a 1in solid spacer to go between the block and mount and use longer bolts.
