Anyone Put A Olds 455 In A Blazer?
HEAVY METAL
Maple Ridge B.C. Canada
just picked up an '69 olds f block 455 rocket... was wonderin if any of you ahve doen the same? any tips, tricks? any input would be greatly appreciated yo! :D
It should bolt in maybe need pontiac to chevy mounts I can't remember if my bro had to use special mounts when he put a Pontiac 400 in his camaro but it fit in that. I would think it would bolt in like a 454 would.
I know that wasnt much help put it def sounds doable. What kinda numbers are you looking at with that thing.
Ira
my friends got a 455 in his 86 C-10. it fits but is very close to the frame rails. too close to run off the shelf headers.
Something else to consider...
The buick/olds/pontiac/cadillac bellhousing pattern is different from the chevy pattern. Those engines will not match up to a chevy transmission. I've seen a 455 olds in a 2wd pickup, but the transmission was also the olds bolt pattern type. Before chevy started using the 6.2 diesel they used an olds 5.7 diesel, in 1979-1980 or so. I think the guy used those factory 5.7 olds motor mounts on the 455. The olds deisel equiped trucks also had the b/o/p/c transmissions, I guess they were turbo 400s. I dont know if they made any with the 4x4 tailshaft.
The 5.7 diesel mounts are the way to get a "bolt in" deal. Not sure what to do about exhaust. Olds and Pontiac are different. You can get an adapter for BOP to Chevy bellhousing pattern for about $50 last time I checked.
The biggest obstacle has to be the exhaust. The olds motor points the exhaust ports straight at the frame, and the motor is extra wide, leaving little room. Using stock manifolds might give you enough room.
