Anyone running a Lenco transmission ??
IIRC Lenco uses "dog" gears. They only stay engaged under power, that how you can change gears so quickly as soon as the higher gear grabs the lower gear falls away. AS soon as you lift off the throttle you're in NEUTRAL :eek1: Might be a little difficult on the street :D
