Anyone running the Holley TBI?
82355
1 ton status
Bradish Nebraska
I bought a used one for my 1988 V10 Suburban. I got it on there and running. The fuel pressure is low. I had an adjustable regulator on my GM throttle body. Is the one on the Holley adjustable? Anyone have a manual for one of these?
Martin
I am running the analog projection. The pressure regulator is adjustable on the back of the tb using an allen wrench. 2 or 4 barrel? I can get either manual.
-Jacob
Here is the 2d manual which is similar to the analog 2 except for the pink wire hookup:
https://docs.google.com/file/d/0B83-MdX1dCWMNUI3ckk5S19lZ0U/edit?usp=docslist_api
Here is the analog projection 4(it may be missing a troubleshooting page or two), it is what I am now running as I wasn't getting enough fuel with the 2 even with the pressure abd tps voltage cranked up too high:
https://docs.google.com/file/d/0B83-MdX1dCWMQUw0eXd4UWllYmM/edit?usp=docslist_api
If you need the manual for the closed loop box I can get that too. If you need me to email you the pdfs because the links aren't working you can pm me.
-Jacob
I just have the stock TBI replacement. It has bigger throttle bores and uses the stock TBI harness.
Martin
Those instructions just say to check the fuel pressure. They don't say anything about adjusting it.
Martin
There is an adjusting screw on the top of the tb, at the back.
I have one on a 350, and anything over 7psi is really rich. I think the injectors are 80pph.
