surpip
1 ton status
Awsome ill try it soon for sure. Especially with smog coming up soon
(and no wonder its so expensive to have a house painted now!)
--she called a few days later,said her car was "pinging" a little,but it went away after she filled it with premium..I later learned that Naptha in the paint and hardware section was much less!
--but its not anymore!!
)--all the stuff is bogus 99% of the time..just a way to cash in on the current situation..
I understand you want to be helpful, but when you dont have your facts straight, you screw up the thread because then your misinformation needs to be corrected.
fatbob said:Dirt,
Please quit while you are behind. I agree with surpip that you need to get your facts straight BEFORE posting. You could not even relay what your father did correctly.I understand you want to be helpful, but when you dont have your facts straight, you screw up the thread because then your misinformation needs to be corrected.
I dont dispute that adding Acetone might increase GAS mileage--but what about pistons,rings,and valves per mile??
I would not add something potentially harmful to MY gas tank unless I"m trying to blow up and old motor on purpose!
I'd hate to find out after paying 16 bucks a gallon,that I did gain 1-2 mpg,but melted a piston or burnt a valve in the process!
