I was going to suggest the pulley idea too--one friend of mine has a hand cranked boat winch anchored to the back wall in his shop,and the cable runs up the wall,and over two pulleys,one on the wall above the winch at ceiling level,and another pulley in the center of the truss in the middle of the shop....
That way he can crank up or lower the winch cable from safe distance away..it works well for removing the cap off his pickup or lifting heavy items to load in the bed,but sometimes you need to be close enough to the lifted object to steady and guide it,and you cant,being a few feet away operating the winch,like when your pulling an engine,etc..he plans to upgrade to a Harbor Freight electric winch with a remote control to overcome that issue ..
I would like to put one of my 1500 lb. winches on my trucks crane,manual cranking is tough for me,but I dont use it often enough to justify all the effort of wiring it,making a 4 solenoid power in-out switch,and then have to worry about it getting stolen..
