Anyone use these guys for carbs?
The description says "calibrated to stock specs", is your engine modified?
I used www.smicarburetor.com I'm very happy with the carb and it was custom built to my engine specs. That said, they but my carb ($250+frt) I did not buy an off the shelf unit.
Also, I have had one issue with the carb but they were quick to warranty it and cover freight. Once repaired though I figured out the problem was probably due to high ethonal gas, not their work.
Nope, no major engine mods. Performer intake, RV type cam and long tube headers. So the stock specs should work for what iv'e got going on.
PAULY383, my good friend had bought one from them, lives in an emission compliant county and as far as I know, as long as he has run that carb he never had an issue with it running bad or even had any issues with passing emissions tests for several years.
I got mine through Summitt Racing and it started right after installation.
So i called and talked to them, calibrated to your engine specs, correct linkage studs and ready to run. 295 plus 19 bucks shipping, gonna give it a whirl.
^^^For sure. Can't wait to put it to use. Kind of busy this weekend though. But I have everything to bolt it on and go, even ordered up a new pump to carb hard line. Looks like next weekend for sure. Could use another set of mounting bolts.......hint, hint.
Well got it all bolted up, took awhile to source the correct throttle/TV cable bracket (thanks to Gonicgm for hooking me up). Sweet running Q-Jet for sure, just had to adjust the idle down a bit. Yes I would recommend this carb dealer to anyone. Nope its not quite efi but works great, can't wait to try some off camber with it. :D
