Anyone using a klune-v?
DesertDueler
Phoenix, AZ
I know I have posted this before but no one said they were running one. I was seeing if anone is now, or if they know anybody with one.
I think your better off posting this on the pirate board, more people run them there...just about everybody here that runs anything like that runs a ORD doubler, are you planning on running it with a NP 241?...if so, 2.72x4.00= 10.88 Not Bad!
I wouldnt use the 4:1 sewt up, I would use the golaith one that is 2.7:1 since its more for bigger motors. But with that setup it would give me a crawl ratio of 102.48:1 Not bad. I have a th400-203 setup already, but then I loose OD and then I would have to regear front and rear to something like 3.73s and then do the 3.6:1 low for the 203 to make it close to that low of a ratio, but it would still only be 66.6:1
