Anyone with 6 inch Rough Country Springs?
88trailblazer
Miami, Florida
I picked up a used set and on the front set only one side had steel degree shims on them. For some reason the other side was missing. I mounted them on the truck for now without the shims for now. I was going to write to Rough Country to get a replacement, but i'm not sure if it came with them or the previous owner added them.
Any one have a set of front 6 inch springs that can check?
i have 6" skyjackers and they also have a shim attached.
I have a set of thos shims sitting on my workbench that I pulled off of a 6" lift once... you can have them if you want them.
How much would they be shipped to 33183? How thick are they? The one that i have is maybe 1/4 inch on the low end and 1/2 inch on the high end.
I doubt that it's 1/2" on the thick side. I believe the 6" springs are treated with 4* or was it 6* shims. Just had my Superlift 6" leaf out and now I can't remember.
Here's mine. Ideally you'd want the shim the same width as the springs. This narrow shim started to crush my driver side perch.
47b8d739b3127cce985481bfff7700000046100IZMWLVw5bsQ
