cdoggwsu
So the steering box (along with the PS pump and hoses) on my '88 Blazer was leaking severely so I figured I'd save some money on a reman'd one (180 bucks at schucks) and pick up a full rebuild kit from West Texas Off-Road for a more reasonable $45. After tearing the box down and replacing everything I figured I'd reduce any more possible problems by taking the box down to the chevy dealership and having them set the over center and input shaft preload.
Well the first time I dropped it by the shop called shortly after and said that the input shaft wasn't lining up properly so I picked it up, cracked it open and found a few of the little ball bearings had fallen out of the worm shaft track. So after putting it back together and following every step in the shop manual was able to get it back to them and they got it all set. I bench tested it for tightness and correct centering, everything looked good and I bolted it up adding an ORD bolt in brace along with a new PS pump, lines, a magnefine filter and a new drag link.
I bled it no problem but there was still a serious amount of play in the steering wheel to the tune of almost 90 degrees in both directions and it was so hard to turn it felt like there was no power steering at all. After checking everything I come to find that all of the play is in the input shaft and by turning the steering shaft (XJ swap) by hand I can see the input shaft is actually moving IN and OUT a little when it is turned.
Could this be from the shop not setting the input shaft preload correctly, or did I screw up again on getting the ball bearings installed? Is there something I'm missing about how those bearings are dropped in or what? I'm totally fed up at this point and considering just buying a reman'd box even though I'm already into this one about 90 bucks. Aside from going all out on a PSC or AGR box that probably won't see crossover or hydro assist for quite some time, are there any other options for "upgraded" boxes?
FWIW, the tech at chevy (a pretty knowledgeable guy) told me they don't even bother rebuilding them by hand anymore as it's easier to just swap them for a reman.
