wasted wages
1 ton status
When you engage an ARB locker,,,does the diff consume a lot of air to keep it locked ??
I guess what I'm asking,,is there a high "bleed rate" of air pressure to keep it engaged or does the locker "hold" the air pressure pretty good until it is turned off...
I was wanting to possibly run a front ARB off of a small bottle of nitrogen
( regulated of course) instead of using an air compressor. If it only requires a small amount to lock it up,,seems to me a small cylinder would last all
weekend....
what say you ???
weekend....
what say you ???
