I have in hand a new ARB air locker and pump for my D60 front axle in the K5. I’m looking for suggestions on where to mount the pump. Should I plumb up an air tank, and if so location?
I have a Detroit locker in the rear. At some point I want to replace that with an air locker. Might be sooner rather than later. If I don’t get the front done soon, I will probably pick up a rear locker and do both diffs at the same time. Right now the D60 is sitting empty while I line up someone to do the install. I will do all but the diffs myself. I won’t attempt those with no lift, too old and worn (mostly worn) to manhandle them laying on the floor.
One battery on passenger side, room for pump on the other side. I have a winch, would that change your approach? I’ve considered putting in a second battery, or do I need something better than the stock alternator?
