ARB question.
doonjumper
Visalia, California
The last time I ran my ARB the compressor would cycle on about every 30 seconds or so. That would indicate an air leak right? I got out the ole soapy water but couldnt find an external leak. Before I tear the cover off to check the fittings I would like to know if anyone else has had this problem. The compressor never cycled on and off before. The compressor would build pressure and keep it until dissengaged. Thanks in advance
sorry cant help with your ARB but i noticed you are from visalia. I grew up there, live in alabama now. Good luck with the compressor
Not sure what version of ARB compressor you have; on mine (which is sort of ancient...) there have been a few leaks over the years at the O-ring between the compressor and the little reservoir/airtank.
